Block Shear Rupture on a Gusset Plate
Good Morning,
I am using AISC DG 29 Vertical Bracing to check some connections. If I am checking blocking shear rupture on a gusset plate with a SINGLE ROW of Bolts, would my failure path be only the dimension of the bolt holes? Check figure 5-2b if you got it.
RE: Block Shear Rupture on a Gusset Plate
That doesn't mean that block shear isn't possible; you can have block shear to a free edge, but this is unlikely to control for a single line of bolts assuming normal edge distances.
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
www.americanconcrete.com
Also, we have design examples from AISC spanning many years, and they have never checked block shear on a single line of bolts. That's a pretty good indication that it is not a check we need to concern ourselves with.
