Weld Assistant - Weld Point Wizard - Resistance Spots/Clinches -- Not correctly visualized in TcVis
Anybody who knows anything about this?
Working with NX.10.0.3.5 and TC 10 (10.1.2.2(20141010.00)) 64-bit, resp TcVis 11.2. Using Weld Point Wizard
(single points) to create Resistance Spots and Clinches between 2 parts. The points are created in a separate
model (container model, only for weld features) wich is a component of an assembly.
Having released the container part, the points are not correctly visualized when opening in TcVis. All Resistance
Spots are visualized as crosses and the Clinches are spheres. In NX they are spheres (Resistance Point) and cylinders
(Clinches), as they should be. Why do they apperar in a different shape in TcVis?
Thanks in advance for any inputs / Reg. / DCM
RE: Weld Assistant - Weld Point Wizard - Resistance Spots/Clinches -- Not correctly visualized in TcVis
Anyone having experince of using Weld Assitant and function "Fill"?
How to work with faces with variating topology?
Reg. / DCM
