HRSG Steam Drum - Design for Vacuum Conditions
For a HRSG Steam Drum, does ASME Section I, mandate vacuum design check? In other words, is it correct to say that all HRSG Boiler steam drums are required to be designed for full vacuum by ASME Section I?
Please be kind enough to reply.
RE: HRSG Steam Drum - Design for Vacuum Conditions
I trust this is sufficient.
Many thanks for your response. My question was if Code mandated full vacuum design for the steam drums. I have gone through ASME Section I carefully, but could not find any requirement. Just wanted to be sure.
General Blr. CA,USA
