Composite/metallic shim in Ultrasonic Inspection
Hi all,
I would like to hear any opinion in the subject of Ultrasonic inspection in composite laminates having a metallic insert or shim.
I have heard about some Ultrasonic inspections where the shim is not detected, some of the theories is that the composite/metal compaction is good that the ultrasonic inspection is not able to capture it.
RE: Composite/metallic shim in Ultrasonic Inspection
Could you recommend some books or manuals related to this topic?
Thank you
UT works on the reflection of waves at interfaces. How much is reflected is based on the difference in acoustic impedance of the material. Acoustic impedance= {density of the material} x {velocity of the wave in the material}. So if you have a metallic plate that is close to the acoustic impedance of the surrounding composite, more of the wave will pass through the material than be reflected, thus making the plate difficult to detect.
This page has the equation for % reflection from interfaces of different acoustic impedance:
https://www.nde-ed.org/EducationResources/Communit...
Here are some online training references that should be helpful:
http://www.olympus-ims.com/en/resources/tutorials/...
