Axis system problem
Axis system problem
When create new axis system on some Body, and make sketch, if use line, direction of line is not (for example)by new axis X - but by direction H. How change or add new axis system with new direction of H and V? When i add new axis system H and V direction is same.
RE: Axis system problem
When using the Sliding option the Part file origin is going to be the default origin location and orientation. The positive H and V will align with the corresponding part positive directions depending on support plane selected.
--Doug
