Partlist arrangements
Hi All,
I've made a big assembly consisting of metal sheets. For production purposes we split this assembly into several pieces. In the model environment I've done this with arrangements.
In the master model draft I've put each arrangement on a different sheet. On each sheet I've added balloons with item numbers referencing the part list on one (central) sheet.
To make things more easy for guys on the floor i'd like to put a part list on every sheet/arrangement. This part-list should only contain the items which are ballooned on that sheet.
Can this be done ?
Lars
Lars
NX10.0.3.5 native
Solid Edge
Inventor
