Material Identification
Experts,
Recently, we got a additional work to perform in BOP piping. In that drawing list, Under bill of materials i saw in the material column "ASME B36.10". So what does it mean?? If i referred the particular section under para 3, nothing illustrate there. Actually, i have to choose proper WPS.
Attached pict for all your reference.
Lemme come out from this
RE: Material Identification
Yeah Noted..!! Any additional information about the materials???
The isometric which has been shared has lot of information missing. Is this the same isometric which was Issued for construction and is being used for redlining now for additional work.
An IFC isometric must have Piping material specification, Fluid code, temperature, pressure, insulation thickness, coating requirement, PID number mentioned, which are missing in the isometric shared by you.
