Siemens NX Drafting - Move Section Symbols Manually
Hello All!
That means the section line lies very far from the sectioned object and i want it to be closer to the hole. I'm familiar with Border to Arrow Distance option, but i want to move the section symbols manually. Is it possible in 9.0.3.4? I've looked and find an independent section lines mechanism in NX 11, is it a solution?
www.CADabout.ru
I need to create a section view of the hole, which is located on the existing drafting view. A default Section View line allows me to gain the result, same as on the picture below:
www.CADabout.ru
RE: Siemens NX Drafting - Move Section Symbols Manually
www.nxjournaling.com
www.CADabout.ru
