REuse of HI-Lok Pins
I have debate here with my colleague,
Is it possible to reuse the pin of an Hi-Lok once its been removed?
Please help me settle this issue.
Thank you
Thank you
RE: REuse of HI-Lok Pins
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
I guess the risk of an unnoticed defect is too large.
And no one won any prize.
B.R.
Mor
Quick review of my philosophy on male [screw-bolt-pin] fastener re-use in general... hope it makes sense.
If the assembly has never been placed in service, and bolt/pin is in clearance or transition FIT, then I generally agree that removal/reinstallation [may re-use the nut/washer if visually OK... but Collars and damaged parts must always be replaced. IF the Bolt/Pins are used in a low-stress mechanical installation, [pivot shaft, etc], then wear is usually not a factor... except for cad-plated steel [rusty?]. Notes. Most washers and Nuts, should be replaced if they have been in-service any length of time: they are cheap and not worth the time to inspect in detail.... unless of course, they are special nuts or are in a low-stress/benign environment... then I might have a different opinion about replacement.
IF the assembly has been in-service for any significant length of time, and IF bolt/pin is installed in clearance or transition FIT, and IF the R&R is to facilitate other maintenance... then common Dia/grip-length bolts/pins should only be removed/reinstalled IF there is a 'process in-place' for detailed inspection: NDI, DI, finish-condition, threads, heads etc... to re-confirm all aspects are serviceable. GENERALY, for small Dia, common grip-length Bolts/pins, the individual cost of inspections to mitigate risk associated with re-use, generally dictates that the bolts/pins be replaced. This assumes that the screw/bolt/pin removal does NOT damage the pin or the hole at that time!!!!
IF the bolts/pins are in any significant interference fit, then they are often damaged trying to remove [press/knock-them-out] them... so the risk/reward is very POOR... hence I just recommend 100% replacement. CAUTION: IF the bolts/pins are a VERY UNIQUE type [IE: Taper-Loks] or are a unique size [for me: over 1/2-inch or a weird oversize-Dia or grip], then the cost of trying to salvage them MAY be reasonable, relative to the high cost and/or long-lead-times in re-procurement. I have gone to extraordinary lengths to salvage large-Dia and/or long-Grip length Taper-Loks, simply because they are very expensive or very hard to get or require next over-size [tapered hole] if being replaced... which means a costly re-drilling process. IF I am salvaging these parts then I have to demand very specific/careful removal practices to ensure they, AND the HOLE, aren't irreparably damaged trying to get them out.
NOTE. Each unique fastener must be 'match-coded' to the specific hole that it was removed from, to have a high probability of a 'good fit'. IF the male-fastener-to-specific-hole match is 'lost' then the situation often is a waste of time/effort. Even though Bolts/Pins are technically identical, the parts are actually a wear-match to a specific hole from which it was removed from. NOTE: I usually insist that the part be reinstalled with grease/CPC [mechanical] or primer or sealant [structural].
NOTE. I have seen hardware [screws/bolts/nuts/washers] for panels, doors, etc that were "slap-ass-wore-out", simply because there was no procedure in-place to inspect the parts for serviceability; and field and depot maintenance had 'Catch 22' views on 'who' should spend the $$ to replace the hardware [not-in-my-budget]... so the old/worn-out stuff lives on. This is just wrong. GAAAAAAAAAAAAHHHHH!
NOTE.
IF this is a homebuilt aircraft, and I'm working-on-it and paying-for-it, then I tend to understand margins and might slide these statements around. Otherwise I won't mess with certificated aircraft and other lives on-the-line... or even a homebuilt if it has low margins of safety.
CAUTION. The FAA is very specific about parts: "last mechanic to touch-a-part for any reason [install/adjust/calibrate/etc] is ultimately responsible for it's airworthiness".
Regards, Wil Taylor
o Trust - But Verify!
