Power output of a cordless drill attachment (epicyclic gearbox)
I'm trying to design an epicyclic gearbox that steps up a cordless drill's rpm ten fold (can't alter the drill itself - it's supposed to attach to the drill to power some attachments). However, I am struggling to find a suitable power value for my calculations (no drill manufacturer shares this information). How can I go about finding a suitable power output (for reference, I'm designing around an 18V, 1.5AH battery) and does it differ under no load and maximum load or should the power stay the same whereas the torque or rotational speed change?
RE: Power output of a cordless drill attachment (epicyclic gearbox)
Typical power out of a gearbox will be less than power in; depends on the gearbox, but say, 90% for a good one of this type.
Electric motors have varying efficiency. At 0 RPM they have 0 efficiency. At maximum speed there is no torque and again, efficiency is 0. See http://electronics.stackexchange.com/questions/237...
If you only need a few gearboxes it would be cheaper to buy cordless drills and steal the gearboxes (using them as step-up) than to design and build your own. If you need large quantities try Alibaba.com
je suis charlie
