NX9 - Drafting Preference Question
If you go to MENU / PREFERENCES / DRAFTING
Then select under COMMON - LETTERING
You find the setting for "Text Justification".
So far as I can tell, this seems to control both Notes, and Dimensions. Is it possible to set Notes and Dimensions different from each other?
When placing notes or labels, we want these to be "Left" justified, but when we place dimensions, these would be better served to be "Center" justified.
RE: NX9 - Drafting Preference Question
I don't think it's possible. There is only one customer default for justification and it is listed for all text, not specific to the type of text.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
