analysis of column with eccentric loading
i am doing the analysis of column with eccentric loading with vertical load applied at some distance from the column, so that the column fails by compression at the side of bending. The reinforcing steel goes on yielding at the compression side at the the end of linear phase and after that the reinforcing steel undergoes plastic deformation .after that the curve in bending moment vs deflection , instead of being horizontal , it is increasing linearly .i could not understand the reason
RE: analysis of column with eccentric loading
