HP Steam Superheater Performance in Sulfur unit
HP steam is generated from waste heat boiler at two places in Sulfur unit of the Petroleum Refinery one at reaction furnace and another at incnerator downstream equipment.This saturated HP Steam(261 deg C-Design value) is routed to Superheater where it is superheated to 391 deg C(Design value).Design value of Saturated HP Steam pressure is from 47.5 kg/cm2g to Design value of Superheated HP Steam pressure is 43.6 kg/cm2g.Superheater is Shell and tube type where Incinerator flue gases are used to superheat steam. (Shell side :Flue gases)
The area of concern is that actual superheated HP Steam temperature remains lower than design at 365 deg C (43 kg/cm2g actual pressure) against 391 deg C design value.
There are total 03 trains parallel to each other in Sulfur units in addition to this, all the tail gases passes through common TGTU unit, TGTU offgases are equally distributed to incinerator in three trains. other two trains Superheated HP Steam temperature remains close to the design as compare to one train where above concern/problem is faced.
potential causes for performance and remedial measures are requested.
Thanks in advanced.
Thanks in advanced.
RE: HP Steam Superheater Performance in Sulfur unit
Dejan IVANOVIC
Process Engineer, MSChE
Thanks.
Presume the total BFW flow to each train is the same.
Is the fuel gas demand to the burners for each incinerator more or less the same? Or is it less than the other 2 for the train which is producing steam at 361degC ?
Good luck
luis
If indeed all TGTU offgas is manifolded before distribution to the 3 incinerators, cannot think of a reason why only train 3 superheater would be fouled on shellside.
Could it be insufficient combustion air to train 3 incinerator, resulting in formation of sulphur rather than full oxidation to SO2? - highly unlikely.
a) some maldistribution of reactor product streams ( with fouled reactor 3 product going predominantly to incinerator 3) or
b)there is insufficient O2 for incinerator 3, leading to sulphur deposition on superheater tube OD.
If the former is not possible, then suggest checking the combustion air flowmeter for incinerator 3 for some readout error (presume this is a forced draught furnace).
Thanks !!
Else it could only be sulphur deposition due to insufficent combustion air to the TGTU tail gas FD burners at the incinerator. Check if there is a bypass damper on the comb air blower discharge that may be leaking or a blocked feed air strainer to the blower etc.
