REQUIRED PIPING DOCUMENT CHECK LIST
RE: REQUIRED PIPING DOCUMENT CHECK LIST
You asked: "What kind of Piping documents should I ask for from the plant to provide to execute a good review."
Consider these:
Typical Piping Deliverables
This list is intended to be as comprehensible as possible. However, the typical Piping Project will not normally require every deliverable listed here. There will also be projects that will require a deliverable that is not listed here.
Piping Material Engineering
Specifications
• Piping Line Class Material
• Piping Commodity Purchase Specifications (Pipe, Fittings, Flanges, Valves, etc.)
• Piping Specialty Item Specification
• Piping Pressure Testing Specification
• Piping System Internal Cleaning Specification (Standard)
• Piping System Internal Cleaning Specification (High Purity)
• Positive Material Identification, Traceability, and Certification Specification
• Piping Painting Specification
• Pipe Commodity and Safety Marking Specification
• Galvanizing Specification
• Hot Piping Insulation Specification
• Cold Piping Insulation Specification
• Acoustical Piping Insulation Specification
• Coatings and Wrapping of Underground Piping Specification
• Welding - General and Hygienic Systems Specification
• Piping System NDE Specification (non destructive Examination)
• Non-Metallic Lined Piping Systems Specification
Data Sheets
• Specialty Item Data Sheets
Drawings (Vendor)
• Specialty Item (Vendor Catalog or Certified Drawings)
Lists
• Piping Line List (originate and maintain)
• Piping Specialty Item List (originate and maintain)
• Piping Commodity Catalog (originate and maintain)
Calculations
• Maximum Allowable Flange Ratings
• Pipe Wall Calculations
Data Files
• Relational Data Base (3D geometry for electronic modeling)
Plant Layout & Piping Design
Specifications
• Plant Layout and Piping Design Specification
• Electronic Design Model (3D-PDS) Specification
• Field Survey/Close Range Photogrammetry Specification
• Piping Tie-In Specification
• Shop Fabrication and Handling Specification
• Field Fabrication and Installation Specification
• Heat Tracing Specification (Piping, Equipment, and Instruments)
Drawings
• Piping Standards
• Plot Plan (s)
• Pipe Line Transposition (Internal only)
• Piping Layout Studies and Vessel Orientations (Internal only)
• Plant Equipment Location Control Plan (Internal only)
• 3D Plant Design Model Index
• Piping Drawing Index
• Piping Plan Drawings
• Piping Section Drawings
• Piping Isometrics
• Revamp Demolition Drawings
• Tie-In Location Index
• Tie-In Isometrics
• Heat Tracing Manifold Index
• Heat Tracing Plans
• Heat Tracing Details
• Heat Tracing Isometrics
• Piping Stress Sketches (Internal only)
• Piping Material Sketches (Internal only)
Lists
• Interference Reports (Internal only)
• Piping Isometric Index (Internal only)
• Tie-In List (originate and maintain, including hanging tags in the field)
Calculations
• Dead weight loads for structures (Internal only)
Data Files
• 3D Model
• Final Electronic Data Base
Piping Material Management & Control
Specifications
• Field Receiving and Handling Specification
• Field Receiving Geographic Color Code Specification
Drawings
• (None)
Lists
• Piping Isometric Bill of Material
• Piping Material Summary (Preliminary, Intermediate, and Final)
• Shortage and overage reports
Calculations
• Piping Material Cost Estimations
Data Files
• Material History (Item and source)
Pipe Stress Engineering
Specifications
• Piping Flexibility Design Criteria Specification
• Pre-Engineered Piping Support Elements Specification (Misc. Field supports, Anchors, Guides, etc.)
• Engineered Piping Support Elements Specification (Spring Hangers, Spring Can Base Supports)
• Metallic Expansion Joint Specification
• Elastomer Expansion Joint Specification
• Pipe Restraints and Shock Arrestor Specification
Data Sheets
• Engineered Spring Supports
• Engineered Expansion Joints
Drawings
• Pre-Engineered Pipe Support Elements Details (150 +/-)
Lists
• Piping Stress Log (Internal only)
Calculations
• Individual pipe line analysis in accordance with the project criteria (Internal only)
Data Files
• Piping Flexibility Analysis Records (Internal only)
Sometimes its possible to do all the right things and still get bad results
nice again, mr Pennock smile
ituation is like that- Plant bulit in 2010 and lot of shut down happened in last 6 years . Now we decided the to design and construction review. Is the plant really bulit according to engg documents and requirements
