NX9 Parts list query- Parts list grouping parts
So Im setting up my parts list template in NX using attributes. I just want a simple parts list with ref no, material & qty. I have sorted this out easily enough although the problem I am having is that if I have more than one part made of the same material it groups the materials together and increases the qty . Example.
Assembly has 3 parts, 1 steel part and 2 plastic parts. The two plastic parts are different shapes but instead of my parts list showing 3 items it shows 2 , ref 1 steel qty 1 off and ref 2 plastic qty 2 off
What I want is ref 1 steel qty 1 off, ref 2 plastic qty 1 off, ref 3 plastic qty 1 off
Any ideas of how I can stop the parts list grouping the parts together?
RE: NX9 Parts list query- Parts list grouping parts
You need the designate the column that defines different parts as the key field.
https://vimeo.com/album/3065578/video/106565338 is our video on parts lists and explains how the key field works.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
