wear analysis in abaqus
Hi everyone
Im simulating a pipe under pressure distribution and looking forward to run a wear analysis on the pipe surface.
is there anyone who can help me toward a correct path?
RE: wear analysis in abaqus
There is an example in the documentation:
See Example Problems Guide 3.1.8 Tread wear simulation using adaptive meshing in Abaqus/Standard
The other (but not recommended) way is to create a really fine mesh and use material damage definition with element removal. But that analysis would run an extremely long time.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
