Aircraft Structures Analysis
Hello everybody,
I wish to hear your views on aircraft structural training. I did some research and found out two possible online courses:
1. PSA1 edu
2. ASSA certificate from AMC academy.
What are your thoughts? Did anyone attempt to enrol, what are comments??
PS. If you know of other courses suitable for P21 design engineer, please do share :)
Dru
1. PSA1 edu
Dru
RE: Aircraft Structures Analysis
I would recommend you get his book first or at least have a look at the contents page. The course is reading each chapter and then doing the example questions plus some additional questions. The most valuable part is that your answers are marked by Jean Claude himself and explanations given if you are wrong.
Yes I was referring to the Practical Stress Analysis by Jean Claude Flabel. Was not sure about it first however after receiving a follow-up email, it seems good to consider as a starter. From your personal experience how long does it take to cover the course on average?
The other course is a certified one: 'Aircraft Structure Stress Analysis' however they do not provide literature reading.
@Stezza: What wold you recommend as a continued study/ OJT for A/C design changes requiring stress analysis.
http://cybered.ca/
The instructor taught me aircraft structural analysis, when he was a college instructor, and Simon B's aircraft structures courses are still based on his college curriculum.
The majority of his course is taught from Bruhn's Analysis and Design of Flight Vehicle Structures.
I have a copy of Flabel's book, and I believe I would use it more often if I had taken his courses, but my grounding with Bruhn has been sufficient for much of my structures work so far.
STF
I am still deciding whether to opt for the Flabel course to get the ball rolling. Hopefully the company can provide/identify further training courses (fingers crossed).
