Internal gear Positive displacement Pump(Motor BKW too high because of Ext. Relief valve set press.)
REBOILER CIRCULATION PUMP
CAPACITY: 95GPM
DIFF PRESS.: 17.92 PSI
DISCH. PRESSURE: 78.8 PSIG
VISCOCITY: 124.6
VAP PRESS.: 73.86 PSIA
BIDDER OFFERED MOTOR OF 15HP BASED ON EXTERNAL RELIEF VALVE SET PRESSURE OF 145 PSIG.
RATED POWER WAS ONLY 1.98HP @ 165RPM.
ISN'T THE MOTOR RATING TOO HIGH???
CAPACITY: 95GPM
VISCOCITY: 124.6
RE: Internal gear Positive displacement Pump(Motor BKW too high because of Ext. Relief valve set press.)
unfortunately THAT'S NOT CORRECT, I HAVE OTHER TAGS WITH MOTOR RATING AS LOW AS 5hp FOR SAME PROJECT BUT DIFF ITEM.
But that's what i am amazed of.why??
Geor- No there is no any other RV except inbuilt internal RV with these viking pumps
Else install another normal capacity / backpressure recycle valve set at a lower pressure and add a margin to this pressure to ensure you have some margin on motor hp ( usually at least 10% between max operating hp and motor rated hp). For this case, select credible coincident upper or lower limit physical properties for this fluid that will demand more hp.
