What rubber sheet properties describe what I want to do?
If I would like to poke a hole into an unstressed rubber sheet with a sharp awl and have the sheet "rebound" and close the hole (as much as possible) upon removal of the awl, what are the property/properties called that I seek?
My thinking is that "elongation" and "compression set" are important but I'm not sure and want to ask suppliers good questions and know which numbers are important on data sheets. Thanks.
RE: What rubber sheet properties describe what I want to do?
