Caesar II Dynamic Analysis
I am having an issue with Caesar II that I have never encountered before.
When setting up new Earthquake (Spectrum) load cases for ASCE7(05) horizontal and vertical, I input the following:
Load Case #1
0 ASCE7(05)Spectrum1H 1.0 X-Direction
2 ASCE7(05)Spectrum1V 1.0 Y-Direction
Load Case #2
0 ASCE7(05)Spectrum1H 1.0 Z-Direction
1 ASCE7(05)Spectrum1V 1.0 Y-Direction
When I go to run the dynamic analysis, the line number in the first case that is "2" changes to a "1" and I get error messages
stating that the load cases are input incorrectly.
Has anyone ever encountered this before or knows of a solution.
RE: Caesar II Dynamic Analysis
one solution is to use some other software!!
Open a Support Request (SR) on Smart Support and send in your job files. Tech Support will look at this and get back to you.
Richard Ay
Intergraph CAS
I think since the OP was in October 16 that he would have solved the problem by the 11 December!!!!
