Pipe2CAD new versions
We've been using a software called pipe2cad, which is an autocad add-on, to solve interference between utility networks and draw longitudinal profiles. I think many people were using it but the problem is that it has no new versions and the latest one works only on autocad 2010.
Has anybody found a newer version of this software or moved to a good alternative?
RE: Pipe2CAD new versions
Are you using it as an interface between a package like EPA-Net? If so, http://www.glamsen.se/CadTools.htm might be an option.
