Newtonian Pressure Drop vs Non-Newtonian Prssure Drop
I did some experiments on Newtonian and non-Newtonian fluids measuring the pressure drop through a horizontal pipeline. The Newtonian two-phase flow was water+air and the non-Newtonian was (water+xanthan gum)+air.
I prepared 2 samples (2 concentrations) of the xanthan gum solution 1g/1L (995 kg/m3) and 2g/1L (990 kg/m3). I am wondering if it is logical that the Newtonian pressure drop was bigger than the non-Newtonian one?! Also the 2g/1L sample should've been with a higher density comparing to the 1g/1L!
RE: Newtonian Pressure Drop vs Non-Newtonian Prssure Drop
Yes the velocities were the same for both. The purpose of the work was to compare the pressure drops at the same rates. The xanthan gum solution gets less viscous as the shear stress increases so, when we increase the flow rates, the shear stress increases and it will result in a small pressure drop. While just the opposite happens with the newtonian fluids at the same rates. what do u think?
The key is the fluid's shear stress to shear rate curve.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
chicopee, yes please I'm really interested.
Thanks guys.
Good luck,
Latexman
Good luck,
Latexman
Good luck,
Latexman
1) take the mystery out of non-newtonian fluids- march 2001
2) pressure drop for non-Newtonian slurries-may 2000
3) predict friction loss in slurry pipes-September 1992
A much older article by Martin H. Wohl:
1) Designing for non Newtonian fluids-January 1968
There are possibly updated articles, however, by that time, much to my regret I stopped subscribing.
I found good topics answer some of my questions. Thanks so much.
chicopee, Thanks a lot.
