Terminology / Nomenclature
A simple question for the pro's of this forum.
Are the term flaps used exclusively for devices on the trailing edge of an airfoil,or can flaps also be found on the leading edge.All my prior experience and education had led me to use the term flaps when being applied on the trailing edge,with the name slats being used to those devices attached to the leading edge.Recently,on another blog I got in a discussion,as to this issue,he produced several references that made me believe I had been misusing these terms for many years,or has the terminology changed and I was a sleep ?
RE: Terminology / Nomenclature
Keep em' Flying
//Fight Corrosion!
In my mind, the classification is more about operation. Flaps are devices that increase the camber and therefore the CL by rotation of a portion of the profile. Slats accomplish the increase camber by translating a portion of the profile. Although I guess this is not always true as a "gurney flap" is completely stationary.
Keep em' Flying
//Fight Corrosion!
Andries
This is what I was taught in college,and had witnessed in industry,it's also what other practicing engineers believed.
I have to go with those definitions,and they seem much more in line with past and current theory.Whoever popularized these terms I refer to I can't determine.It's almost as if it's one person saying something,then seeing it in print,on the internet,no less,and that terminology being taken as the Gospel.Sort of create your own terminology.Glad I still have a pretty good pile of books around,and still burn my money by continuing my collection.We and society are going to be in one Hell of a shape if we never do have a massive electromagnetic wave war and all this electronic data and knowledge gets destroyed.
I think flaps were named as such potentially because of their deployment motion - that is, they "flap". So it doesn't really matter if they are installed on the leading or trailing edge.
I understand this is a discussion of common nomenclature. But a quick look at the NASA NTRS pulls up some matches of reports of NACA tests talking about "leading edge flaps" as early as 1947, and maybe earlier. Also, Sighard Hoerner's monumental textbook "Fluid Dynamic Lift", Chapter 6 Section 2, is devoted to leading edge or nose flaps.
It seems there is history for this term.
Keep em' Flying
//Fight Corrosion!
The F-16 and FA-18 have leading edge FLAPS. They are hinged off of the leading edge spar and work in concert with the trailing edge ailerons and flaps. The LE flaps alter camber and are capable of independent movement relative to each other, depending on flap and aileron control commands. They not only alter camber for lift enhancement, but add roll-rate when differentially activated... which is necessary with very heavy wing-store loads [high roll inertia]. In addition these devices have a secondary but very important function: when roll is commanded using ailerons or flaperons together there is a very serious torque on the wing-box; the LE Flaps generate opposite torque-loads [relative to the trailing edge control surfaces] providing a counter-torque to the wing box. The LE Flap counter-torque is essential for minimizing wing aeroelastic twist that could add very high/runaway/destructive torque-loads to the wing-box. Essentially the 'active' LE flaps, independently controlled by the computers, allow the jets to see MUCH higher wing [lift/roll/dynamic] loads than static structure would permit.
Wing leading edge SLATS are like traditional flaps in that they function 'in concert' [same movement, LH RH wings] and are exclusively for lift enhancement. All slats that I'm aware of, actually push-away from the wing-box... which has a second stub leading edge sculpted under the slat... which does 3 things: (a) increases wing-area as the slat moves forwards; (b) forms an aerodynamic gap between the SLAT and the wing structure that forces entrapped airflow [thru the gap] over the wing upper surface to the trailing edge; and (c) in concert with the wing trailing edge FLAPS [which usually increase wing-area aft-ward while increasing camber and torque] tend to balance wing-box torque loads. This would be typical for most new transport acft.
NOTE. The SLATS added wing leading edges of older fighters [F-4, F-100, etc]... where flaps/ailerons are hinged off the rear spar... and were intended [added] for airflow control to enhance fighter lift/roll maneuverability for low-to-high subsonic dog-fight speeds [enhance lift and delay stall when in high G pitching/rolling maneuvers].
NOTE. SOME older Boeing transports [707, 727] have both 'plain leading edge flaps' and SLATS. The plain LE Flaps hinge-down from the under the leading edge to increase camber [primarily in the 'thick' LE area of the inner 1/3 of the wing LE span]... and have the classic extendable/flow-gap SLATS on the outer ~2/3's of the wing LE span. for enhanced lift and roll-controllability.
NOTE.
Some STOL aircraft have SLATS for all the purposes mentioned... but especially for enhancing lift and roll control... so they can safely fly at ridiculously low airspeeds.
Regards, Wil Taylor
o Trust - But Verify!
Learned more here than Ae 344,along with practical aspects,with regards to structures.This discussion also allowed me to revisit Chapter 6 "Leading Edge High-Lift Devices",by Hoerner & Borst,it's all here,Sorry for such a common question.Must have been asleep during those lectures,in school.
