Electronic chlorine metering pumps
Need sugestions concering manufacturers / models of electronic feed pumps to supply chlorine treatment on a small public water supply system. Must meet ANSI/NSF Standard 61 for Drinking Water System Components.
Require pump with genral ratings of:
Max capacity: 5-10 GPD
Max Pressure: 250 psi
RE: Electronic chlorine metering pumps
Unfortunately while there are many quality manufacturers of metering pumps your selection for NSF 61 approval is limited.
LMI is the only manufacturer that has that approval. For your application an 'A' series pump will be fine. Make sure you request a de-gassing valve to prevent the pump from locking up.
You could find more information on this pump at www.panner.com
Glenn
BobPE
John
