Steel Skid NDT inspection Section V
Hi guys,
We have a steel structure as a skid. Which techniques and criteria we have to follow as per Section V for NDT inspection.
In which per of the code I can find it?
Thanks.
Thanks.
RE: Steel Skid NDT inspection Section V
r6155
1- This is a structure of beams, columns and plates, welding performed shall be done as per ASME Sec. IX. We have a note that NDT shall be per Section V.
2- Material is Carbon Steel, A36/44W
3- It’s a skid with platforms, ladders, catch basins, grating with overall dimension 40’ x 10’
I want to know in this case if section V force us to do any specific test? if yes which one? And per which clause?
ASME IX contains requirements for the qualification
of welders, welding operators, brazers, brazing operators,
plastic fusing operators, and the material joining
processes they use during welding
ASME V contains requirements and
methods for nondestructive examination (NDE), which
are Code requirements to the extent they are specifically
referenced and required by other Code Sections or referencing
document.
As you post “We have a note that NDT shall be per Section V”, this note need to specify which NDE is required, the extension and acceptance criteria
Example:
1)all buttwelds in beams shall be 100% RT, ….
2)all fillet welds shall be 10% PT, ….
r6155
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
And Yes ASME SECT IX can be invoked but to use and comply with Sect V you will need more than just the Code Book,
