Fire Protection Standards Canada
Hi all,
I am currently working on the development of a power plant project intended for Canada. No exact location yet but it is intended for mines in remote areas that do have have grid connections. The plant will consist of a thermal plant producing steam, steam turbine, diesel gen backup and typical balance of plant.
I am based in South Africa and so am not familiar with the fire protection standards used in Canada. The projects I am involved in typically use NFPA 850 etc. Is it the same for Canada or are there local standards I should be aware of?
Thanks for your help.
