Unable to import SLDPRT and SLDASM in NX-8.5.
RE: Unable to import SLDPRT and SLDASM in NX-8.5.
I would suggest getting a neutral format file such as STEP. NX 8.5 is about 4 years old now; if the SLDPRT is from a version of SolidWorks released after NX 8.5, then NX probably won't be able to read the newer file format. Check the NX 8.5 MR and MP release notes; the ability to open other file types is occasionally updated through MR's or MP's. If you must be able to read that version of SLDPRT file, you will probably need to upgrade to a newer version of NX.
www.nxjournaling.com
Not knowing what your intent is beyond opening or importing, would Parasolid work for you?
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
The file the OP was using is from Grabcad. I downloaded the model and will only read into NX10 or later.
The version of Solidworks that the file is created in is too new for NX8.5 or even NX9.
Get NX10 and it will work with no issue.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
Ok I will wait till NX-10 is installed in my system. Thanks you all
