Opening second NX
Opening second NX
Hello, is it possible to open the 2nd NX when one is already open? Without Teamcenter it was possible and it was quite handy to work 2 projects at the same time. I have NX9 and Teamcenter 10.
Thanks in advance.
Thanks in advance.
RE: Opening second NX
Anyway, the process involves editing the start_nxmanager.bat file. If you search the Siemens "Solution center" for: "How to launch NX without launching Teamcenter and use AW from NX". You should get some info, this is where I started.
Use with caution.
-Dave
NX 9, Teamcenter 10
An easy task seems so difficult to do as always in NX...
Ben Loosli
