DC/AC INVERTER
DC/AC INVERTER
I'm looking for an DC/AC Inverter with the following specifications:
Input: 200 to 460V DC
Output: 208/240V 3 phases, 6-8kW
This inverter powers an AC motor that drives the power steering, AC and air brake on hybrid-electric utility truck.
Any help will be greatly appreciated,
Thank you,
Loic Gaillac
Southern California Edison
Electric Vehicle Technical Center
loic.gaillac@sce.com
Thank you,
Loic Gaillac
RE: DC/AC INVERTER
RE: DC/AC INVERTER
http://www.metricmind.com/ac_honda/motor.htm
Others:
http://www.dimensionsunlimited.com/industrial.html
http://www.xantrex.com/products/supercat.asp
6-8 kW seems to be higher than what's mostly available. Can you use two smaller inverters?
TTFN
RE: DC/AC INVERTER
The inverter should be operational within the all range of voltage (220-460V).
Loic
RE: DC/AC INVERTER
RE: DC/AC INVERTER
Loic
RE: DC/AC INVERTER
http://www.thomasregister.com
and type Inverters under Product or Service which will return 140 companies to choose from
