ASTM A234 - Gr 4130
ASTM A234 - Gr 4130
ASTM A234 - Gr 4130
There are companies advertising fittings as A234 - Gr 4130. It doesn't appear that any of the A234 grades listed in table 1, of the ASTM specification, have the chemical composition range to allow 4130. How are they doing this?
RE: ASTM A234 - Gr 4130
Which companies? Foreign? There are fittings supplied as 4130 with no reference to A 234.
Other than by not following the rules?
In some spec systems (SAE) people often take exceptions.
Under the rules of ASTM you cannot identify a material or product as meeting a spec unless it meets all of the requirements, no exception allowed. Occasionally you see something marked as "ex" but it is a tighter or additional requirement
metengr,
Yes, the companies are based in the UK. I've attached a screenshot from one of their specification pages.
EdStainless,
That is what I thought. Section 5 of the ASTM A234 specification doesn't appear to allow for variance outside of the values listed in Table 1.
Thank you both for your input.
