Partial 3D Section
Partial 3D Section
Does anyone know if you can do a Partial 3D Section in a product using the DMU license? I am trying to take some cross sections for a presentation and I would like to show a shot where a subcomponent is not sectioned but the structures surrounding it are section cut. Any thoughts?
Ryan Capriglione
NX/CATIA Power User
RE: Partial 3D Section
please be aware that assembly feature on instance is a known problem...
I played around with the sectioning tool today, but couldn't find a way to do what you need without some workaround like itsmyjob described. If anyone finds a way to do this please share.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
I do not see any possibility of it in spa2 sectioning.You can try Assembly pocket where you can draw a sketch by skipping the parts that does not need cutting and create a assembly pocket involving only those parts for sectioning.Hope it helps.
Ryan Capriglione
NX/CATIA Power User
See attached image.
