Screw Centrifugal Pumps for RAS/WAS and Diffused Aeration
Hello:  Does anyone know of a domestic producer/supplier of screw centrifual pumps other than hayward gordon?  need an alternate to provide a competetive bid.
also, need a medium bubble diffuser manufacturer/supplier other then envirex.
thanks, rob
RE: Screw Centrifugal Pumps for RAS/WAS and Diffused Aeration
Schrieber Corporation of Alabama makes screw pumps.  See www.schrieberwater.com.
Don't know for sure about the medium bubble diffusers.  EDI of Columbia, MO makes an excellent fine bubble diffuser.  Might try Enviroquip too.
For the bubble diffuser, try EDI, I have had the best luck and dependability from those folks.
KRS Services
www.krs-services.com
for screw centrifugal try Wemco-hidrostal
for diffuser try EDI or Wilfley Weber, Inc.
Hidrostal from switzerland are used extensively in Australia on this duty.
Maybe it is too late now, but you can contact andien in Argentina, they have verly good prices in aeration equipment www.andien.com.ar
mmo
ABS Pumps now have the Nopol range of diffuser assemblies. They are common on major plants in Australia.
Sharing knowledge is a way to immortality
Check out "Lakeside".  They're from Illinois.
