low voltage reverse battery protection
I have 3 strings of lithium batteries. 4S3P. I need to protect each string from reverse protection and charging. What is good method to this that has a very low voltage drop, less than 100mV at 2 amps.
I look at schotkey diodes, their forward voltage drop is too high. Using an O-ring controller seems too complicated and too leaky. Any other suggestions?
RE: low voltage reverse battery protection
Keith Cress
