Jack and Slide Beam Design
Anybody familiar with these beams?
Where I can get some information on specifics of design of these beams?
Thank you
Thank you
RE: Jack and Slide Beam Design
Dave
Thaidavid
Yes. But, we really can’t see your problem from here, so you might get better discussion and answers if you wasted a bit of your time to actually define your problem with a enough specificity so we knew what you were actual dealing with. That description might include type of equipment and type of move being anticipated, weights, dimensions of loads, type of moving and lifting equipment on hand, etc. I’m often surprised these days that any engineering problems ever get resolved, given the way questions are asked and the way the problems are defined and presented.
