NX9 - Journal code to toggle edges hidden by edges
To be clear from the start, this is for views already created. I need to create a button that will automatically select all views on a sheet and toggle "edges hidden by edges" on and off.
The reason I need this is because when they are left on, too often hidden hole diameters will look almost solid because it is showing the edge of both sides of the hole and the dashes do not line up. Yet, we need to turn them on while selecting the side view of a hole to place the origin of an ordinate dimension. Which we do a lot. Too often people will add the dims but never turn the edges hidden by edges off again and the prints end up making some hidden lines look solid. It would make it much easier for people to just select a button to turn this option on and off for all views on a sheet.
Any help with this would be appreciated.
RE: NX9 - Journal code to toggle edges hidden by edges
Anyone? ........ Anyone? ..... Bueller?
Below is the journal code in VB. Tested on NX 10.0.3.5
CODE --> VB
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports System.Collections.Generic
Imports System.Drawing
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports System.Environment
Imports NXOpenUI
Imports NXOpen.Annotations
Imports NXOpen.Drawings
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Form1
    Inherits System.Windows.Forms.Form
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()> _
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    Public theStatus As Boolean
    Friend WithEvents ButtonON As System.Windows.Forms.Button
    Friend WithEvents ButtonOFF As System.Windows.Forms.Button
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    <System.Diagnostics.DebuggerStepThrough()> _
    Private Sub InitializeComponent()
        Me.Button1 = New System.Windows.Forms.Button()
        Me.ButtonON = New System.Windows.Forms.Button()
        Me.ButtonOFF = New System.Windows.Forms.Button()
        Me.SuspendLayout()
        'Button1
        Me.Button1.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.Button1.Location = New System.Drawing.Point(54, 96)
        Me.Button1.Margin = New System.Windows.Forms.Padding(2)
        Me.Button1.Name = "Button1"
        Me.Button1.Size = New System.Drawing.Size(81, 23)
        Me.Button1.TabIndex = 0
        Me.Button1.Text = "Cancel"
        Me.Button1.UseVisualStyleBackColor = True
        'ButtonON
        Me.ButtonON.Location = New System.Drawing.Point(12, 12)
        Me.ButtonON.Name = "ButtonON"
        Me.ButtonON.Size = New System.Drawing.Size(161, 23)
        Me.ButtonON.TabIndex = 16
        Me.ButtonON.Text = "Turn ON"
        Me.ButtonON.UseVisualStyleBackColor = True
        'ButtonOFF
        Me.ButtonOFF.Location = New System.Drawing.Point(12, 41)
        Me.ButtonOFF.Name = "ButtonOFF"
        Me.ButtonOFF.Size = New System.Drawing.Size(161, 23)
        Me.ButtonOFF.TabIndex = 17
        Me.ButtonOFF.Text = "Turn OFF"
        Me.ButtonOFF.UseVisualStyleBackColor = True
        'Form1
        Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.ClientSize = New System.Drawing.Size(188, 130)
        Me.Controls.Add(Me.ButtonOFF)
        Me.Controls.Add(Me.ButtonON)
        Me.Controls.Add(Me.Button1)
        Me.Margin = New System.Windows.Forms.Padding(2)
        Me.MaximizeBox = False
        Me.MinimizeBox = False
        Me.Name = "Form1"
        Me.Text = "Edges Hidden by Edges"
        Me.ResumeLayout(False)
    End Sub
    Friend WithEvents Button1 As System.Windows.Forms.Button
    Private Sub ButtonON_Click(sender As Object, e As EventArgs) Handles ButtonON.Click, ButtonOFF.Click
        Dim btn As Button = CType(sender, Button)
        If btn.Name = "ButtonON" Then
            theStatus = True
        Else
            theStatus = False
        End If
        Me.DialogResult = DialogResult.OK
    End Sub
End Class
Public Class MainMethod
    Private Shared theSession As Session
    Private Shared theUF As UFSession
    Private Shared theUI As UI
    Private Shared lw As ListingWindow
    private Shared turnOnEdgesHiddenByEdges As Boolean
    Public Sub New()
        Try
            theSession = Session.GetSession()
            theUF = UFSession.GetUFSession()
            theUI = UI.GetUI()
            lw = theSession.ListingWindow()
            turnOnEdgesHiddenByEdges = False
        Catch ex As Exception
            Throw ex
        End Try
    End Sub
    Public Shared Sub Main()
        Dim theMyClass As MainMethod = Nothing
        Dim theUndoMark As Session.UndoMarkId = Nothing
        Try
            theMyClass = New MainMethod()
            'Call Show form
            theMyClass.showTheForm()
            UI.GetUI().NXMessageBox.Show("MyForm", NXMessageBox.DialogType.Error, ex.ToString)
        End Try
    End Sub
    Sub showTheForm()
        Dim theForm As New Form1
        If theForm.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
            turnOnEdgesHiddenByEdges = theForm.theStatus
            processDrawingViews()
        End If
    End Sub
    Sub processDrawingViews()
        Dim workPart As Part = theSession.Parts.Work
        Dim markId1 As NXOpen.Session.UndoMarkId
        markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Toggle Edges Hidden By Edges")
        For Each vw As DraftingView In theSession.Parts.Display.DrawingSheets.CurrentDrawingSheet.GetDraftingViews()
            Dim views1(0) As NXOpen.View
            views1(0) = vw
            Dim editViewSettingsBuilder1 As NXOpen.Drawings.EditViewSettingsBuilder
            editViewSettingsBuilder1 = workPart.SettingsManager.CreateDrawingEditViewSettingsBuilder(views1)
            editViewSettingsBuilder1.ViewStyle.ViewStyleHiddenLines.EdgesHiddenByEdges = turnOnEdgesHiddenByEdges
            editViewSettingsBuilder1.Commit()
            editViewSettingsBuilder1.Destroy()
        Next
    End Sub
End Class
Suresh
www.technisites.com.au
tested on nx8.5
Run to flip/change setting
Run again to restore setting
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Module list_all_views_on_current_drawing_in_display_part
Dim s As Session = Session.GetSession()
Sub Main()
Dim workPart As Part = s.Parts.Work
Dim draftViews As DraftingView()
draftViews = s.Parts.Display.DrawingSheets.CurrentDrawingSheet.GetDraftingViews()
s.ListingWindow.Open()
For Each draftingView As DraftingView In draftViews
's.ListingWindow.WriteLine(" " & draftingView.Name.ToString)
If draftingView.Style.HiddenLines.EdgesHiddenByEdges = True Then
draftingView.Style.HiddenLines.EdgesHiddenByEdges = False
Else
End If
workPart.DraftingViews.SuppressViewBreaks(draftingView)
draftingView.Commit()
workPart.DraftingViews.RestoreViewBreaks(draftingView)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
 Sub Main()
     Else
     End If
   Next
 End Sub
 End Function
End Module
Added 'Undo'
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Module flip_on_off_edges_hidden_by_edges_of_current_drawing_views
 Sub Main()
   Dim markId1 As Session.UndoMarkId
   markId1 = s.SetUndoMark(Session.MarkVisibility.Visible, "Start EdgesHiddenByEdges")
     Else
     End If
   Next
 End Sub
 End Function
End Module
I removed these lines and this also work
I do not know why
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
 Sub Main()
     Else
     End If
   Next
   Next
 End Sub
 End Function
End Module
Excellent!
I will be honest, I didnt try them all, but this last one being the shortest I tried first and it worked great. Thank you very much. Hopefully I can learn from it and make similar codes on my own so I dont have to keep bothering people here. clown
If you value succinct code, the following code
CODE
Else
End If
can be reduced to:
CODE
'toggle value of "EdgesHiddenByEdges" property
draftingView.Style.HiddenLines.EdgesHiddenByEdges = Not draftingView.Style.HiddenLines.EdgesHiddenByEdges
www.nxjournaling.com
Yes that's good
Thank you cowski
But what are those two lines that i removed
What they do.
Quote (a984928)
I do not know why
I'm going to go out on a limb and say that these lines suppress and restore the view breaks. I'd suggest testing the code on a drawing that has view breaks to see what the effect is (if any). Perhaps the view breaks need to be suppressed before updating the view (I'm not sure, I have not tested the code).
