Transient analysis of cable under gravity
I'm working on a model of inclined cable, consisting of LINK 180 element in transient analysis under the effect of its own weight only. I added an imaginary damper to damp the oscillation to reduce numerical error. The model works correctly as long as the "TENSION ONLY" KEYOPT in LINK 180 isn't activated, once I activate "TENSION ONLY", the solution never converges.
The APDL code is attached Link
Thanks a lot for help!
RE: Transient analysis of cable under gravity
NLGEOM is ON, and I tried this prestress effect and nothing changed. Do you have another suggestion?
Thanks a lot
/solu
antype,static
pstres,on
nlgeom,on
deltim,0.005
acel,,9.81
solve
finish
