rod x-bracing connection to web with hillside washer
I need some guidance on how to design a hillside washer to
web connection. Is there a published design guide for this
which I can't seem to find?
I have searched and searched with no luck.
thanks
thanks
RE: rod x-bracing connection to web with hillside washer
http://www.thesteelsupplyco.com/blog/bid/105048/Hi...
BA
BA
I'm still surprised there isn't a table with published values for this situation.
Why don’t you ‘bit the bullet’ again, you already ‘made a risa fem plate model’ and build us all that ‘ table with published values for this situation.’ Everything in this world doesn’t come for nothing or a quick Google. Maybe a nomograph would be a better presentation for such a problem. Maybe some of the variables would be load and its angle, double pl. thickness vs. col. web thk., double pl. width to height a/b. You could also show some yield line solutions to the problem and how they compare with the FEA solutions. Then provide a welding design btwn. the column and the doubler pl.
