VB code For Changing Color Pallette?
If it helps, I use Visual Basic and Unicode in my Interface Preferences
I have tried the code mentioned in previous threads to switch to the SYSTEM COLOR PALETTE. I dont know if I am screwing up adding it to another journal or if it doesnt work for me because maybe it was done in C++ or what, but it gives me a bunch of "not defined errors" or "Not declared errors".
Why I need to do this is because our template we use to create new jobs is a GM template that uses a GM Color Palette. But for different reasons, we need to use the System Color Palette. Most of the time, our designers do not bother to switch the palette. So I want to add it to another journal that most of our people do use.
I have wanted to find the GM template we use and change that but I have never been able to figure out how to do that. Add to a journal, some code to change the palette seems the easiest answer.
