Filler Rod designation
Fellow worker needs to finish an engineering drawing and lost his email notes.
We are welding 4130 tubing to other thin shapes for a support structure.
Weld per AMS-STD-2219. I will strongly suggest that this specification be ordered which will likely answer the question 1 and 2 below.
Use Filler Rod ER70-S2. This designation is in question.
He thinks it might have a 3 that he is leaving out.
1) Is this filler rod call-out an AMS spec?
2) What is the closest designation to that shown above that would be correct for this application?
Thanks in advance for your help,
Leonard
Leonard
Jesus is THE life,
Leonard
RE: Filler Rod designation
this: Filler Rod per ER70S-2. Supposedly.
Therefore new questions are:
1) Is this AMS or AWS or who's spec?
2) Is filler metal called out or referenced in AMS-STD-
219?
Jesus is THE life,
Leonard
ER80S-D2
E stands for "Electrode"
R stands for "Rod"
The first two or three numbers are an abbreviation of the weld's strength. To figure out the strength of the weld, take the 2 digits, in this case 80, and multiply by 1000 to get the weld strength in PSI.
S stands for solid electrode or rod.
If there is a letter and number combination next, it relates to the chemical composition of the weld deposit.
(NONE)--Mild Steel
A1---Carbon Moly
B1---1/2 CR, 1/2 MO
B2---1-1/4 CR, 1/2 MO
B3---1-1/4 CR, 1 MO
C1---2-1/2 Nickel
C2---3-1/2 Nickel
C3---1 Nickel
D1---1-1/2 MN, 1/4 MO
D2---1.25-2% MN, 0.25-0.45% MO
G---Alloy not designated
M---conforms to military specs.
For parts thicker than .120", stress-relieving is recommended and 1,100ºF is the optimum temperature for tubing applications.
Thanks loads that helps my memory graetly.
Can you answer the following:
219?
Jesus is THE life,
Leonard
2. MIL-STD-2219 does not have a requirement for "x" filler rod to be used with "y" steel grade. I seriously doubt that AMS-STD-2219 does either.
It looks like DoD handed the ball (MIL-STD-2219) off to SAE and now SAE fumbled it. From the SAE website:
AMSSTD2219 : Fusion Welding for Aerospace Applications (Cancelled Sep 2002) 09-04-2002 Standard
The purpose of this document is to provide minimum requirements for weld filler materials, workmanship, inspection and record requirements for fusion welding of alloys applicable to aircraft, missiles, other aerospace equipment, their parts and accessories.
Also cancelled: AMSSTD1595 : Qualification of Aircraft, Missile and Aerospace Fusion Welders (Cancelled Sep 2002) 09-04-2002 Standard
This standard establishes the procedure for qualification of welders and welding operators engaged in the welding of aircraft, missiles, other aerospace equipment, and their parts and accessories by fusion welding processes. This standard is applicable to aircraft, missile, and aerospace ground support equipment or other welding, when included in the contracting documents or when invoked in the absence of a specified welder qualification document.
Anyone needing the specs. MIL-STD-2219 and MIL-STD-1595A should download them before they disappear from the ASSIST site (http://assist2.daps.dla.mil/quicksearch/).
I think u can use ER70S3 filler rod without any fear. This is an AWS specified electrode.
Good bye.
Farigh
