API 527 bubble size
API 527 bubble size
API 527 bubble size
Hi All,
Struggling with my geometry.
API 527 states a tube of 6.12 ID (7.9 OD x 0.89 WT) at a depth of 12.7mm under the water surface to measure the bubble leakage.
Although not stated in API 527 the bubble volume is 0.295 cm3, however using 4/3.pi.r^3 this does not equate to 0.295 cm3.
I dont imagine the depth of the water has a significant effect upon the bubble geometery, can someone explain where I'm going wrong or offer the solution please.
DT
