Hello, I have prepared an extern
I have prepared an external application for copying the publication from one CATPart to other CATPart which are in the same Product. I have to group this publications under single body in Destination CATPart. Also I have to keep the Hybrid design option disable. Issue is my group is created and the publications are copied below it. I want this publications within the group. Please help if any option is there in CATIA.
Kindly find the attached image for reference.
Thanks and Regards,
Yashodeep
RE: Hello, I have prepared an extern
just add more actions in your script so it will make Boolean operation with the mentioned bodies...
Eric N.
