Parts List customization in NX 9.0
I am using NX 9 and am trying to customize my parts list a bit. I see the options to show single level, and to show leaves only, but is there some intermediate where I can choose which parts to show single level and other parts to show leaves only? This would be helpful because some of our sub assemblies are assembled at a different facility, while we assemble others here, but they all feed into the same master assembly. So for parts that we assemble, I want to call out all the leaves, while the parts we get from our other facility that are already assembled I want to show in a single level style. Is there a way to easily do this?
RE: Parts List customization in NX 9.0
Take a look at attribute:
PLIST_IGNORE_MEMBER
PLIST_IGNORE_SUBASSEMBLY
from the assembly where you want create the
"part list" select in the assembly structure the part
and set this attribute to 1
this will not include the part (MEMBER)
or the subassemby (SUBASSEMBLY)
from the part list
N.B. to remove this option delete the attribute
don't try to set to another value.
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
NX 10.0.3.5 MP3 64bit
www.studiotreccani.com
I've read up on those attributes prior to posting. The difference between what I am trying to do and what those attributes supply is this:
P_LIST_IGNORE_MEMBER ignores the immediate member, but not the components that are used to create the member (sub-assembly components).
P_LIST_IGNORE_SUBASSEMBLY ignores BOTH the member, and its sub-assembly components.
I am looking for an option that ignores only the sub-assembly components, but not the member itself. I suppose this may be able to be done if I use P_LIST_IGNORE_SUBASSEMBLY for the sub-assembly components, leaving the attribute on the member alone, but I haven't had a chance to try that yet.
I've called the NX support for something like what you want some time ago and they have open an ER.
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
It seems that when I have the parts list set to do leaves only, if I set all the leaves of a particular sub-assembly to be ignored, then it ignores the parent member as well. It would be very helpful to avoid entering the parts in manually, any other suggestions would be appreciated.
www.nxjournaling.com
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
I think I did find a way to get this to work, but it doesn't involve the attributes. It seems that with "top level only" turned on, I can use the "select/deselect subassemblies" tool to get the job done. I have to first deselect the sub-assemblies that I wish to expand in the parts list (if they are selected then the sub items are highlighted in a lighter color, and won't appear in the parts list). After deselecting these parent members, I can then begin selecting the sub items that I wish to show up in the parts list. It's a long process with a large assembly, but this seems to have worked for now.
