RT on thin wall (4.5mm) tubes
Hello, We are trying to take RT on 4.5mm economizer tubes with Gamma rays and ASTM wire penetrameter in D5 film as per contract. But we are unable to achieve 5th with clearly and consistently. The SFD calculations are perfect.
Can anyone throw some light on this matter.
Dilip Kumar R
Valmet Chennai.
Dilip Kumar R
Valmet Chennai.
RE: RT on thin wall (4.5mm) tubes
If it is source side IQI it should be a number 6 wire.
r6155
Thank you. Source side. And 5th Wire is contractual requirement. Moreover, none of the wires are visible.
r6155
