nx constraint validation Solution
thread561-379792: Constraint Validation
I found the solution for thread561-379792: Constraint Validation. It is just a setting.
In the customer defaults - Assemblies - General - Product Interfaces, the "Assembly constraints" was set on "Encourage Use of Interface Object". This caused the warning every time I added a component to an assembly.
Regards, Michel
Groeten, Michel
I use NX9.0.0.19
HP Z420 Intel Xeon 3.2GHz
Quadro K4000 3GB
64GB Memory
Windows 7, 64-bit
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
