How get center line of hole or tap hole ,circle of hole in drawingview by selection.
I want get center line or circle in drawingview of part 3D.
I tried like that :
Dim itype(0)
itype(0) = "Line2D"
Dim status
status = oSel.SelectElement2(itype, "Select a Line", False)
but key "Line2D" is wrong.
Thank for any help !
RE: How get center line of hole or tap hole ,circle of hole in drawingview by selection.
why don't you just select any element and then check it's type?
Then modify your code to pick only the type you need...
Eric N.
Hi itsmyjob !
this method is difficult because their name is same "GeneratedItem" .
Hi ferdo !
i want create a dimension between two hole.
from 3D, how can do it?
Yes . But I don't know do what with RecPattern , Circular Pattern ,User Pattern hole
Can you help me?
