CATIA VBA error (fresh install)
It might be a common problem, couldn't find solution. So, as fresh install was needed (B25), now I can't get to run even a simple code like this:
CODE -->
Sub CATMain()
    Dim RootProduct As Product
    Set RootProduct = CATIA.ActiveDocument.Product
    MsgBox RootProduct.Name
End Sub
I'm receiving an error (Can't find project or library) right in the first line "Dim RootProduct As Product"
Where there any changes from VB6.x to 7.1? Previously I was working on VB6.
RE: CATIA VBA error (fresh install)
I tried with this (under admin)
C:\Program Files\Dassault Systemes\B##\Win_b64\Code\bin\CNEXT.exe /unregserver
and
C:\Program Files\Dassault Systemes\B25\Win_b64\Code\bin\CNEXT.exe /regserver
but still macros doesn't work... also there was no previous version of catia on this computer it's system (win10) fresh install
From DS Knowledge Base.
Automation usage on multiple level on the same machine can not be done in parallel but only consecutively and with unregistering the first version before registering the new one to switch fron Rn to Rn+x
In the V5Rn installation directory, in a command prompt window, type :
catstart -run V5RegServer -unset
In the V5Rn+x installation directory, in a command prompt window, type :
catstart -run V5RegServer -set ProductLine env MyV5Environment DirEnv MyV5EnvDirectory
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
I have had some old .catvba files containing macros (from B19) and those didn't work in B25 straight away, what I did now is create new .catvba, create and copy/pase codes to newly created macros and it works ...
