NX 10 View Specific assembly arrangement in Modeling
I know you can do this in Drafting, but now I am in modeling creating MBD models. I have created different model views to show my PMI. I have a subassembly (a box) that has assembly arrangements. Lid closed (default) and lid open. How do I show the lid open arrangement in one view but have it closed in the other views?
RE: NX 10 View Specific assembly arrangement in Modeling
at the same time no in modeling no in drafting.
and I hope Im mistaken.
you can do that by the components hide.
Yes you right !
I learened a new tip. Thank you.
did you tried to change the angle say 75 deg instead of 90 deg
I test your solution its work completely good.
in drafting and modeling
Why you say workaround ?
see atached
So I built the views ( I use create explosion only to freeze the arrangement/view )
1. I create a new view by view operation save as and I name it 'exploded_view_arrange_open90'
2. I create a new explosion and name it exp_90 (create only without any actions)
3. I select the arrangement open-90
4. I do view save
5. save part
then I switch to Trimetric view and change the arrangement to closed (default)
and now when I select 'exploded_view_arrange_open90' It shows the arrangement open90
Try it yourself
atached an example box_3
https://www.youtube.com/watch?v=k2F0L7f6FdE arrangement/view
This list for nx assembly for beginner.
https://www.youtube.com/playlist?list=PLM5OmkG4e7G...
http://mechanism3ddesign.com/
Hi vnmold86
Please here we deal with showing 2 or more different arrangements in the
modeling mode views
OK. Let the ball to Siemens. ( Yet I learned something )
