Welding 316l to Super 13 Martensitic UNS S41426 (SM13CRS)
Further to the very helpful response to thread330-393368: Welding 316L to 13Cr - Use 316L wire? I have now been asked to look at welding 316L to Super 13 Martensitic UNS S41426 (SM13CRS)with 110ksi yield - I am trying to understand the recommendations for this - the weld spec says 309 filler wire, is that Ok.
Secondly the recommended PWHT is heat to 1400F and cool to 360F over 3 hrs. The UNS S41426 is a Q&T martensitic steel - so I assume that we will not get anything like the 110ksi yield? What is the yield likely to be then? I don't think we can quench and temper with the 316L material welded to it can we?
RE: Welding 316l to Super 13 Martensitic UNS S41426 (SM13CRS)
EDIT- Sorry i mean to say that the loads through the higher strength material are different than those through the lower strength material.
As a point to weldstan's comment, you better be sure the weld joint design is such that it is truly located in a low stress region or otherwise problems will develop. I can't tell how many times folks were fixated on how to weld rather than to design for DMW's in service.
So we would like
either
1) The weld process including PWHT to not affect the SM13CRS plate yield strength significantly (which I do not think is possible, hence my question)
or
2) To estimate the reduction in yield strength so that we can redesign the plate to take the required load.
If you perform a sub-critical PWHT for the SMSS after buttering it will not reduce the bulk mechanical properties. The sub-critical PWHT should be performed 50 deg F below the original tempering temperature. The purpose for the sub-critical PWHT is to reduce only the HAZ hardness in this application and residual stress.
