Well Rehabilitation
Well Rehabilitation
Is it more effective treating for iron bacteria using Aqua Freed method or a chemical treatment like QC-21 and an acid?
RE: Well Rehabilitation
The growth of iron bacteria can be controlled by disinfection with chlorine. Chlorine can inactivate the iron bacteria and also oxidize the iron. Control of iron bacteria with chlorine is accomplished by oxidation of the ferrous iron which deprives the iron bacteria of their energy source.
Go to a library and have them obtain the book titled "Handbook of Ground Water Development" by Roscoe Moss Company. Some of the chapters are online.
The initial treatment should be chlorination. Periodic treatments may be necessary.
Aqua Feed and QC-21 are not specific treatments for iron bacteria.
What type of well, capacity, and what does the well driller recommend?
The well is a Municipal well with a 14-inch grouted in place casing, to a depth of 531 ft then an open drillhole to a depth of 1286 ft. This runs through Cambrian dolomite and sandstone formations. The well had a capacity of 800 GPM. I still have yet to obtain a yield pump test as to what it is operating at now.
The iron bacteria count is high but still in legal range. The last time I know that it was treated was in 1997. That was with 20° baume muriatic acid and QC-21.
Have not consulted a well driller yet.
