Way to suppress elements to for analysis?
Dumb Femap question of the week:
I'm working on my analysis of a valve in a length of piping. I need to analyze two cases. In the first case, the valve is supported by hangers. In the second case the valve is supported by the pipe. I'd like to keep both results sets in the same file.
So, is there a way to "suppress" the beam elements I'm using as hangers so I can re-run the analysis for an unsupported case? So far all I can do is delete them, which works but isn't helpful for making small tweaks to the model.
RE: Way to suppress elements to for analysis?
create a group with all the elements and a group without the beam elements and in the NASTRAN Bulk Data Options (when you set up the analysis) pick the right group in the menu "Portion of Model to Write"
